Discussion topic: Wifi password
This message was authored by: Mel-123
Wifi password
I cannot connect my ring door bell to wifi no matter how many times I put it in thank you
Re: Wifi password
@Mel-123 What are you trying to connect it to sky Hub wise?
Avatar for Mel-123
Re: Wifi password
Trying to connect my door ring bell to my sky fibre hub thank you
Re: Wifi password
@Mel-123 New doorbell, has it ever been connected before to the sky Hub, what sky hub are you using? Depending on which hub you have you may have to make some slight adjustments to it first!
Video Doorbell setup guide
Avatar for Mel-123
Re: Wifi password
It's all done thank you had to put new password in on sky hub .
Re: Wifi password
@Mel-123 Was there a particular reason that the password had to be changed for Ring doorbell would work, character limit etc had mine on the network for well over four years now and sure don't use any of the Hubs passwords, first thing that is changed always!
