Discussion topic: Wifi password has changed
This message was authored by: Kraig1
Message posted on 24 Jan 2025 11:56 AM
Hi, I had a power cut last night, now only the TV is connected to the WiFi. When I try to connect anything else it says incorrect password
Find out more
Message posted on 24 Jan 2025 12:05 PM
Re: Wifi password has changed
@Kraig1 it is possiblecthe hub hascreset to its factory defaults so you would have lost anybcustom settings. If thst doesnt apply you can reset the black hub yourself by pressing and holding in the reset pin until the power led flashes. On the white hubs press and hold in the WPS button for 30 seconds.
