Discussion topic: Connection issues
Message posted on 19 Nov 2025 07:14 AM
Connection issues
Hi
no sky broadband please helpme
Message posted on 19 Nov 2025 01:01 AM
Wifi off
Message posted on 19 Nov 2025 01:08 AM
Re: Wifi off
Same issue here
Message posted on 19 Nov 2025 02:18 AM
Re: Wifi off
Same here Wolverhampton cut off 2 times. I use 5G network on mobile with hotspot WiFi connected to my PC, lucky 26Gb data left
Message posted on 19 Nov 2025 02:30 AM
Re: Wifi off
Same from this evening in Watford and now Skymobile is down
Message posted on 19 Nov 2025 03:55 AM
Re: Wifi off
Same in Hertfordshire i think it's the whole uk lol ridiculous
Message posted on 19 Nov 2025 04:23 AM
Re: Wifi off
Down here in Newcastle. Box is flashing green and no internet connection but sky say there's no connection issues... brilliant
Message posted on 19 Nov 2025 04:53 AM
Re: Wifi off
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. You don't receive advance notification of this from Sky or Openreach. Hopefully it'll be back up and running before 7am.
Message posted on 19 Nov 2025 07:23 AM
Re: Connection issues
Same issue for me - orange light in internet and voice.
Can we get confirmation on whether this is an outage?
Message posted on 19 Nov 2025 07:37 AM
Hi. Same issue for me too
Message posted on 19 Nov 2025 07:47 AM
@AC1305 @NigelPhillips @Chazzle same advice check the lights on the hub see https://www.sky.com/help/articles/hub-lights-explained-start if thst indicates the hub has lost its connection and a simpke rebootvdoesn't sort it there is a fault. Running the service checker in the My Sky app overca mobile connection will tell you if Sky arexaware of a fault local to you. If it doesnt call Sky to report the issue so it can be checked out.
Message posted on 19 Nov 2025 08:10 AM
My Internet isn't working iv done all the tests unplugged the router and despite it coming back on for 10 minutes it's off again
Message posted on 19 Nov 2025 08:18 AM
Also all tests say ok and no outage, same problem keeps dropping
Message posted on 19 Nov 2025 08:44 AM
I'm in Greater Manchester. It's 8.43am and we've not had WiFi all morning. Anyone know if sky are still denying there's an issue?
Message posted on 19 Nov 2025 08:50 AM
I'm in the London area and I have done all the checks and rebooted. Nothing. Showing as No outage in area
