Discussion topic: Connection issues
This message was authored by: jules090971
Re: Connection issues
Same here in York. Green light on hub but says service is ok
This message was authored by: AC1305
I have the amber light on where it says 'voice' on the hub
Re: Wifi off
Same in York. Green light on but can't connect
This message was authored by: Ashst16
Re: Wifi off
Box green but no internet connection on devices!!
anyone got it fixed?
This message was authored by: KatieH3
Phoned sky and recorded message says been known problem in area and now fixed, but technical team will look into it and respond within 3 days 😂 been dropping out since 7am, and working from home, fingers crossed it's hopefully fixed now. Strange seems to be affecting all areas and no outages reported.
This message was authored by: JoeyBlueEyes
Same here near Manchester - suddenly went out around 8:45am red light on LOS
This message was authored by: Chazzle
Re: Wifi off
Speaking to Sky, they said several exchanges have gone down and that Openreach are already aware and investigating.
Seems that they were only recently aware. If you call I was told they could give me an update on progress via text message.
The current estimate was this evening for a fix.
This message was authored by: Connor3421
Re: Wifi off
Mines fine now, seems to have just turned on
I still have the issue. Is this the same for you guys?
Still same for me but sky says its back on! It isn't
This message was authored by: Ikkleruby
Ours was fixed by about 10am, although it's not perfect. Greater Manchester area.
What is the best number to call?
