1
This discussion topic has been answered Discussion topic: Wifi not working
This message was authored by: Juliette65426
Wifi not working
Re: Wifi not working
@Juliette65426
The extremely hot weather won’t be helping but use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
@Juliette65426
