Discussion topic: No lights on hub
Message posted on 09 Jul 2026 09:21 PM
No lights on hub
Internet was connected as normal and then all of a sudden lost connection and when I check the router/hub it is very hot and has absolutely no lights on it.
Message posted on 09 Jul 2026 10:18 PM
Re: No lights on hub
Have you tried connecting it to a different power outlet in your home to see if any lights are then lit, if they are not then you will need to get in touch with Sky as you might need a replacement.
Message posted on 10 Jul 2026 05:30 AM
Yeah, a different power outlet makes no difference, I think it has just died. It's only been in a month.
