1
This discussion topic has been answered Discussion topic: Wifi not working
This message was authored by: Lis23
Wifi not working
Recently joined sky broadband. Im working from home and the internet keeps going down. Done all the cheeks and its saying everything fine.
Re: Wifi not working
@Lis23
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
@Lis23
