1
This discussion topic has been answered Discussion topic: No Wifi/ Broadband
This message was authored by: JV12
No Wifi/ Broadband
No wifi or broadband, with amber/ red lights on the router. The online portal also says there is an issue, but when running the health check, says that it is all good? Not sure what to do?
Re: No Wifi/ Broadband
@JV12
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
@JV12
