Discussion topic: Wifi not working
Message posted on 02 Jul 2026 05:35 PM
Wifi not working
My wifi cut out and none of my devices will connect and only two lights are on the router. (Power & wifi)
Message posted on 02 Jul 2026 06:17 PM
Re: Wifi not working
@KayaLou26
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Message posted on 02 Jul 2026 06:18 PM
@KayaLou26 run the online srrvice checker in the My Sky app over a mobile connection.Don't be too surprised if it doesnt oick up the dropped connection as it takes up to an hour to do that but once it does it can tell you if Sky are aware of an issue affecting your line or walk you through some simple checks before booking an dnginerr to check your line.
