Discussion topic: Wifi not working
This message was authored by: RH32
Wifi not working
Done the tests recommended. Wifi is not working. There's no access to the internet.
Please resolve this as soon as possible.
Re: Wifi not working
@RH32
We can't resolve it. We are customers like you.
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
