Discussion topic: No wifi
Message posted on 18 Jun 2026 03:41 PM
No wifi
I can't connect to the internet. Your app says there are problems but when I run checks it says it's fine
Message posted on 18 Jun 2026 03:44 PM
Re: No wifi
@Harriet93
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
