Discussion topic: Wifi not working
This message was authored by: Christina85
Wifi not working
My glass TV is saying no WiFi. I have turned it on and off again checked all the wires and reset it like the instructions said. But comes back saying internet connection is down. I am unable to use my TV or get any WiFi for the house. Please help
Re: Wifi not working
@Christina85
If you have no broadband in your property then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
