Discussion topic: Wifi not working
Message posted on 28 Mar 2026 01:08 PM
Wifi not working
The Wi-Fi is not steady and it's on and off. It works for around 5 mins and doesn't work. On the hub, the middle light turns from yellow to orange. I've tried all the troubleshooting suggested by Sky.
Message posted on 28 Mar 2026 01:29 PM
Re: Wifi not working
Try running this line test to see if it finds any faults:
Message posted on 28 Mar 2026 01:45 PM
Thank you for link provided and guidance. Did the line test, results show all ok, did also broadband test and result says all good.
However intermittently the centre light either goes of or turns amber. It turns Green again after sometime. This is repeating since yesterday evening. Never faced such issues earlier.
Message posted on 28 Mar 2026 01:48 PM
Can you try the tests again when it is amber or is it showing that now when you ran the tests ?
Message posted on 01 Apr 2026 07:31 AM
Thank you for the message. Ran the tests again but intermittantly the middle light turn amber but it reduced compared to Sunday. Still issue remains but it amber for sometime turns into green after few mins.
Message posted on 01 Apr 2026 07:38 AM
@Kumaran sounds like an intermittent line fault. If the service checker in My Sky is not picking up the fault and offering to book an engineer call Sky to see if thry can do it from their end.
Message posted on 01 Apr 2026 07:40 AM
