Discussion topic: Wifi not working
This message was authored by: MarkCartwright
Wifi not working
Wifi light flashing Amber but struggling to connect
Re: Wifi not working
@MarkCartwright
See further down about hub lights…
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
Avatar for MarkCartwright
Ran the service checker everything ok but still not working
@MarkCartwright
Follow all the above post.
Can't connect to Internet
Router struggling to connect
Broadband won't connect
Used broadband checker says everything ok but still struggling to connect
Re: Broadband won't connect
@MarkCartwright
Try rebooting your broadband hub at the mains, if this doesn't fix it then give this a try:
Try running this line test to see if it finds any faults:
If this is of no help give Sky a call to report it to them.
Edit - Your posts have been merged into those you made yesterday.
