Discussion topic: Installation Time
This message was authored by: Light2
Installation Time
Hello
I currently have Virgin broadband, will it really take 1 to 2 weeks to install BT broadband when all I need to do is plug a new hub in and have it activated? Thanks for amy help.
Re: Installation Time
@Light2 Yes, VM and OR do not use each others lines at all!
@Light2
Potentially longer at this time of year, because there's a backlog of other work generated by the holiday period.
Avatar for Light2
Thank you for your help.
