Discussion topic: Wifi not working
Message posted on 23 Dec 2025 08:11 PM
Wifi not working
Message posted on 23 Dec 2025 08:15 PM
Re: Wifi not working
@Claireleith
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
Message posted on 23 Dec 2025 08:21 PM
@Claireleith wrote:
All green lights following it not working but no wifi
Also try rebooting your broadband hub at the mains.
