Discussion topic: Wifi not working
Message posted on 24 Nov 2025 11:17 PM
Wifi not working
Message posted on 25 Nov 2025 04:20 AM
Re: Wifi not working
@Sonya-
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
