Discussion topic: WiFi dropped
Message posted on 25 Nov 2025 12:45 AM
WiFi dropped
No WiFi - service checker tells me no issues - then tells me there's a problem- absolute rubbish
Message posted on 25 Nov 2025 04:18 AM
Re: WiFi dropped
@Scoobymiked
When there are broadband issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. You don't receive advance notification of this from Sky or Openreach. Hopefully it'll be back up and running before 7am.
If it isn't, even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
