Discussion topic: Wifi not working
Message posted on 23 Nov 2025 06:15 PM
Wifi not working
Wifi isnt working.
Message posted on 23 Nov 2025 06:38 PM
Re: Wifi not working
@Joana2
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
Message posted on 28 Nov 2025 11:10 AM
No wife having issues all week
Wifi keeps turning off & keeps happening all week
Message posted on 28 Nov 2025 11:22 AM - last edited: 28 Nov 2025 11:26 AM
Re: No wife having issues all week
@Joana2
Edit:
I've merged your post into the one you posted a few days ago. No need for a new thread as it just means duplicate responses.
Did you contact Sky after the initial advice?
Message posted on 28 Nov 2025 11:23 AM
@Joana2 Is it just wifi or is it the broadband internet, are ALL devices not getting anything?
