2
This discussion topic has been answered Discussion topic: Wifi not working
This message was authored by: Luke143
Wifi not working
My wifi is not working its saying connected without internet?
Re: Wifi not working
@Luke143
Use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it)
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
@Luke143 check the lights on the hub https://www.sky.com/help/articles/hub-lights-explained-start as thry will tell you if the hub has lost the connection to the exchange. If it has and unless the Service Checker in the My Sky app or website tells you thst Sky are aware of an issue affecting your line callthem to report the issue.
@Luke143
