3
This discussion topic has been answered Discussion topic: Wifi not working
This message was authored by: Emmamurphy3
Wifi not working
My wifi has just stopped working I have completed and check and it says no issues and all 4 green lights showing on hub. However I work from home and pc won't connect and neither will my phone
Re: Wifi not working
@Emmamurphy3
Use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it)
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
edit- your two duplicate threads have been removed as you already have this one.
@Emmamurphy3
This message was authored by: MarcusW1
I am having exactly the same problem.
@Emmamurphy3  You seem to keep raising the same issue in 2 other seperate threads.  These duplicate threads you have created have been removed.
Please stick to the one thread.
