Discussion topic: Wifi not working
Message posted on 04 Jun 2025 02:42 PM
Wifi not working
Hello,
My broadband keeps going down as of last night at 8pm. I have switch the router off and back on, reset it and nothing is working.
Message posted on 04 Jun 2025 02:46 PM
Re: Wifi not working
@JulieB03
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
For a ‘no broadband’ issue, if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
