Discussion topic: Wifi not working
This message was authored by: HT2810
Wifi not working
We have restarted the box and all the other things needed but the internet light is not lighting up Green.
Re: Wifi not working
@HT2810
(For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support).
▪️I AM NOT A SKY EMPLOYEE ▪️
