Discussion topic: Poor wifi outside of my main room with hub
This message was authored by: Graham_Wood_196
Wifi is good in the main room with hub, but gets progressively worse the further from this room you are. Boosters, which I used with success previously are no good with this system. This means that activity using the internet is now restricted to two rooms only.
Can you help please?
Would a stronger package help or not?
This message was authored by: Doc5907
Re: Poor wifi outside of my main room with hub
@Graham_Wood_196
Assuming you now have the new white sky max hub then older boosters won't work with this hub.
Newer boosters (or Pods) can be obtained by enquiring about Sky WiFi Max so give Sky a call about this. Details below:
www.sky.com/help/articles/sky-wifi-max
Sky Q 1TB UHD
LG TV
Sky Mobile
Avatar for Graham_Wood_196
Thank you for your time, will try your suggestion.
Graham
