Discussion topic: Wifi not working
This message was authored by Alyn1 This message was authored by: Alyn1
Wifi not working
Tonight my wifi had when off to my PC  printer which is hard wired when I use my iPad to air print it can't find the printer either have tried rebooting the router and using the wps button but again nothing happens
Any ideas as I run a small business and I should have said its  sky wifi max I had installed 4 weeks ago
Re: Wifi not working
@Alyn1 can other devices acces the internet? If they can your broadband is working. The printer being detectable for air printing is not likely to be being caused by the Sky hub as it can happen after an update to ios on your devices. It is a pain my own printer can go into a sulk.
Sometimes unplugging the printer and tgen allowing it to reboot works if it doesnt try restarting the Sky hub. There are loads of suggestions if you search online but modt are combination of unplugging and restarting the units.
Alyn1
Thanks tried all off these, after about 3 hours everything came back to normal the time closure seemed to be beween 8.30pm & 11.00pm
Then everything when back to normal, i'm at all loss
Thanks for the insight
