Discussion topic: Wifi not working
This message was authored by: JackP2
Wifi not working
Wifi has been down all day - there has been no option to connect to it from any of my devices.
When I go on the app it says there is a problem with the device then when I click in and run the test it says there's no issues and it's running normally - I'm not sure how it checks this when no devices can connect to the wifi.
The light on the router has been white all day - I've turned it off and on multiple times with no success.
Re: Wifi not working
@JackP2 see this thread to see how to reset the hub which sorts the issue.
