80
Discussion topic: Sky WiFi Max Hub (white): No WiFi but wired connection is ok
This message was authored by SZ1 This message was authored by: SZ1
I have a sky max hub, but at around 2am I lose wifi on all my devices and could not find my router in WiFi list. I have tried to restart my router but it doesn't help.
the wired connection still works perfectly.
Anyone else have the same problem? Is the router faulty?
Moderator note: subject of thread updated to better reflect the conversation
This message was authored by KevNewMedia This message was authored by: KevNewMedia Answer
Re: No WiFi but wired connection is ok
Posted by a Sky employee
Morning Everyone
Thank you for bringing this problem to our attention and thank you @Chrisee for tagging me.
I've escalated this problem to our support teams and as soon as I hear back, I'll let you all know.
I'm marking this post as an answer, so that everyone has the most up-to-date information. This doesn't mean that it's been fixed.
As confirmed by @SZ1 a current workaround is to factory reset the hub by holding down the WPS button for 30 seconds. Once this is complete, any previous changes you've made, will be downloaded again from the cloud.
Kev
Community Manager
This message was authored by KellyWilson1 This message was authored by: KellyWilson1
Wi-Fi not showing as an available network
Had Sky broadband installed last week and my phone connected to it fine. Now I've got nothing. I tried to connect my phone to it again but it's not showing as an available network. Checked on my tv and Firestick and none of them can see the Sky wifi, just my old provider that's luckily still live for a couple of weeks. I've checked the connection and it's showing that it's working fine so I'm not sure what I'm doing wrong.
This message was authored by Sabmenier This message was authored by: Sabmenier
Re: Wi-Fi not showing as an available network
I have the dame issue. Did you find a solution? Anywhere we can call?
No it's still not there
This message was authored by Sharon973 This message was authored by: Sharon973
Gigafast has been installed today and isn’t connecting
My new broadband got fitted today and all the lights are green and the sky max hub has a white light but no devices will connect my sky glass tv won't connect or none of my phones or consoles but when I go on the app it says there's a problem but when I click check wifi it says everything good but it's just not I can't watch the tv because I've got no internet connection
This message was authored by Chris347 This message was authored by: Chris347
Wi-fi connection
The hub is working
my devices are indicating as connected
but, no wi-fi connection
Tried switching off and on, no change
Any suggestions?
This message was authored by Ellie2206 This message was authored by: Ellie2206
Sky Max Hub not connecting to anything
Help my sky max hub won't connect to any phones or my sky box for tv it has a white light saying it's connected and working but when I type WiFi password in to connect it says unable to join network. I have tried switching it off and it waiting before switching on again I've unplugged and re plugged everything I don't understand why it won't connect to anything when it's saying the internet is working.  @Sky
This message was authored by Donna125 This message was authored by: Donna125
I've just had exact same problem around 1/2 an hour later
This message was authored by Francisairens This message was authored by: Francisairens
My hub is doing the exact same thing as you
This message was authored by Sammy88 This message was authored by: Sammy88
Mine down as well nothing but WiFi connected lost tv through the Internet broadband with sky
Mines been last 20 minutes now just went off the TV with sky
Think this bad weather were all having
This message was authored by MunroK This message was authored by: MunroK
I'm having the same problem
Nothing not even name sky router coming up too log with the router think down somewhere or cable down possibly but router fine just no sky tv bedroom or living room
SZ1
I solved this by factory reset the router(press the button on router for 30 seconds). Hope this helps!
