Discussion topic: Wifi not working Again
This message was authored by: PaulineC1
Wifi not working again
Re: Wifi not working Again
@PaulineC1
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
