Discussion topic: Outage in South Wales villages
Message posted on 13 Dec 2025 01:34 PM
There is a complete internet outage in the villages of Nelson, Treharris, Trelewis, Quakers Yard and Edwardsville.
Sky just keep offering bot support because there is no outage in the area according to them.
cant even call them because phone signals have reduced to snail pace and calls are failing.
local businesses are affected and we can't report to get the issue resolved.
i have only got internet on my phone because I have an international e-Sim to travel with 5G and I am having to use that.
Any tips?
Message posted on 13 Dec 2025 01:39 PM
Re: Outage in South Wales villages
@AmandaDavies72
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
