Discussion topic: Wifi no working
This message was authored by: Lisa1012
Wifi no working
I checked on your end says fine but we have no connection in the house
Re: Wifi no working
@Lisa1012
You aren’t contacting Sky Customer Services here. This is predominantly a customer led discussion forum where Sky customers are available to help other customers.
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
