11
Discussion topic: Wifi max pods are wifi 6 compatible?
This message was authored by Micits This message was authored by: Micits
Hi,
Im having some issues connecting my laptops to the pods - both of laptops rather connecting to the hub even though signal in the areas where laptops located is not the best.
Got engineer over to have a look at the issue - all he did is ordered me a new room pod and told me that these pods are not wifi 6 compatible therefore might be the reason for the laptops to connect to the hub instead of pods.
Can anyone confirm this information here?
This message was authored by mae-3 This message was authored by: mae-3 Answer
Re: Wifi max pods are wifi 6 compatible?
The difference between wifi 5 802.11ac and wifi 6 802.11ax is only in its modulation methods. Wfi 6 supports all forms of modulation in 802.11ax & 802.11ac, so it's backwards compatible with all previous standards.
The Pods are actually 802.11ac from my knowledge and not able to use the modulation methods in 802.11ax which is 1024-QAM and allows faster traffic for 802.11ax clients increasing the performance by 25% for the Sky Max router but not for the Pods.
Zen internet on G.fast (250Mbps down, 50Mbps up). SAT> IP (Apple 4K 2nd gen TV to LG C1 OLED UHD TV/Dolby Atmos Denon AVR, DacMagic Plus for Hi-Res audio), hosting own blog/forum (cluster), OPNsense & Zenarmor L4/L7 NGFW & DPI IDS/IPS, Asus ET12 Pro Tri-Band wifi, Linux, Gamer: Xbox Series X/i7 laptop, round-robin DNS over HTTPS, non-proprietary VoIP HD AMR-WB (G.722.2) and more... Beta tester Apple iOS/watchOS/tvOS/iPadOS/macOS.
As far as we know the pods that Sky supply with Max are WiFi 6: Plume certainly has such hardware
However there do seem to be ongoing issues with the Max firmware which affect its performance when interacting with pods.
@Micits
@TimmyBGood just reading up on superuser forum and they described as wifi 5 ac triband which uses some of the lower wifi 6 freqs.  I believe @mae-3 should be able to give more detail
@mae-3
Pretends to understand what you said🤔 😁👍
Micits
Thanks everyone for replying.
This message was authored by JohnDubs This message was authored by: JohnDubs
Hi - did you ever resolve this issue? I am having exactly the same problem where my laptop won't connect to the Pod - only the Hub, even though the Pod signal is much much stronger.
@JohnDubs in the period I had the pods I found the system took 24 hours or more to optimise.
Micits
Looks like sky are not in a rush to solve this one 😂
Are your laptops wifi 6 or 5?
I personally cancelled wifi max as I've spent more time trying to fix it than actually enjoying the benefits of it.
If it helps- you can connect laptop with pod using rj45 wire
other option is - try to play around with wifi bands on windows settings (Removed)
Moderator note: Removed third party link
THanks @Chris - it's been plugged in for 5 days now bt no change.
I have a Sky engineer visit booked so perhaps they will be able to help.
@Chrisee - tagged the wrong person
@JohnDubs no probs suggesting getting Sky out would have been my next suggestion.
