Discussion topic: Wifi lately keeps dropping. Orange light
This message was authored by: Pira21
WiFi not stagke lately ..Orange light
Re: Wifi lately keeps dropping. Orange light
@Pira21
Your post isn't very clear. Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your ISP (Sky).
See further down for guidance on the lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
