1
This discussion topic has been answered Discussion topic: WiFi issues….again and again
This message was authored by: Curtis25
Wifi out since 1am and sky saying not an issue Saying internet is down when done through tv but to check the router- which is all fine. Happening too often and have had engineers out on several occasions with replacement sockets which works but then drops again and we are back to square one. Getting to end of our tether now Any help or advice greatly appreciated or if others have experienced this.
Re: WiFi issues….again and again
@Curtis25
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
@Curtis25
