Discussion topic: Wifi keeps rebooting
This message was authored by: Georgia39
My wifi keeps cutting out and rebooting every 10 minutes or so.
the bill is paid so shouldn't have an issue ? I have tested the wifi connection and it says all okay.
very frustrating to have it keep cutting out.
Re: Wifi keeps rebooting
@Georgia39 if the internet light goes amber when you lose connection it is a line issue which are pretty common at the moment particularly after yesterdays storms. If tge weather is the cause the connection should improve as the lines dry out but you can call Sky to report the issue but what can be done is limited and Openreach engineers will be pretty busy so nothing is likely to becdone quickly..
