Discussion topic: Wifi keeps going on and off
Message posted on 22 May 2026 11:30 AM
Message posted on 22 May 2026 11:42 AM
Re: Wifi keeps going on and off
@Paulaedwards
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
