Discussion topic: Wifi keeps going dropping
This message was authored by: sdmx
For the past couple of days the WiFi keeps dropping  every so often. When this happens, the internet light on the hub is blinking amber. What's going on? Service checker keeps saying everything looks good even when it clearly isn't
Re: Wifi keeps going dropping
@sdmx
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
Avatar for sdmx
Thanks for the reply. I've been doing this multiple times and the updated tests say all good while I'm looking at blinking amber light on the hub. It seems the tests aren't reliable. I'll have to get in touch with sky because this is happening at least once every hour
