Discussion topic: Broadband Internet keeps dropping
Message posted on 04 Jun 2025 10:07 PM
I am getting on my nerves because my Internet has been dropping since yesterday. This is forcing me to use my monthly data, which will eventually run out. I am considering switching to another provider.
Message posted on 04 Jun 2025 10:30 PM
Re: Broadband Internet keeps dropping
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
Message posted on 04 Jun 2025 11:52 PM
Same here! Only since yesterday
Message posted on 05 Jun 2025 06:01 AM
Same applies. If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
