Discussion topic: Wifi keeps dropping
This message was authored by: Michael0406
Wifi keeps dropping
For the last couple of days the wifi has been dropping and disconnecting and then today it has disconnected everything
Re: Wifi keeps dropping
@Michael0406
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
