Discussion topic: Wifi keeps dropping
This message was authored by: Darren622
Wifi keeps dropping
For the last few months on average once a month the broadband drops out. My sky up says everything is good but my tv etc is buffering and my phones says no signal.
Once I switch my sky box off and reset every it works for another week or so.
 I'm getting bored of talking with bots and getting told there are no issues.
If not rectified I will not be renewing my contract later this year.
Warm regards
Re: Wifi keeps dropping
@Darren622
Suggesting you'll not renew is irrelevant here. You aren’t contacting Sky Customer Services here. This is a customer led discussion forum where Sky customers are available to try to help other customers.
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
