Discussion topic: Broadband booster
This message was authored by: edgie700
Broadband booster
Hi all , looking through the masses of sky B/B boosters that are for sale , I want one for my SR203 router , seen a white booster that's the same as my router ( but white ) but it's advertised as a Sky Q Router ??? Thought the Q one was the flat one ??
Re: Broadband booster
@edgie700 You are looking for the Sky Broadband booster, and there are two variants the SE210 original wireless with one Ethernet port, and the later SE210a same but with NO Ethernet port, port was dropped to save cost's and availability off parts at the time.
Link shows you what....
https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with
Avatar for edgie700
Level 4 icon
So basically the advert is wrong and it's not a Q one , glad about that , yes I need the ethernet port on the back , it's so my CCTV can connect to it , thank you once again
@edgie700 PM'd you
Avatar for edgie700
Level 4 icon
Can WiFi boosters , the one to go with the SR203  be bought direct from sky these days ?
@edgie700 Sky do not sell anything hardware wise to customer's all owned by them and let the customer effectively borrow through paying the sub fee forever, and with the old SE's they like to keep them for the sky Q, you will find it VERY difficult to squeeze one out off them but you can only try! You struggling to get a hold off one!
Avatar for edgie700
Level 4 icon
Hi , no I've found one but I always like to buy new , hopefully they don't do fake copies 🤦🏻‍♂️ I'll buy it and hopefully it's all ok , thanks again
@edgie700 Only new i have seen are on Amazon, it's going to be the Ethernet port gamble from them though, surprise when box get's opened!
