12
This discussion topic has been answered Discussion topic: Wifi keeps disconnecting
This message was authored by: Bisobank
My wifi keeps disconnecting. At times it shows connected on my laptop, but no internet. At other times, it is extremely slow. Below is the snapshot of the router statistics.
This message was authored by: Highlinder Answer
Re: Wifi keeps disconnecting
@Bisobank  Do you have a lot of other Wi-Fi instances around you that are maybe stronger than your own?
@Bisobank  There has been no drops on the connection uptime of just around 93 hours uptime. Is this just Wi-Fi devices that are dropping and are all them dropping or just one?
Avatar for Bisobank
All the devices connected in wifi disconnects. It is very obvious with the laptop. After some time, it then reconnects again.
@Bisobankhas it happened in the last few days as there is only 93 hours uptime on the router.
Avatar for Bisobank
Yes, the frequency is so high daily that i sometimes i turn off the wifi on my phone.
Avatar for Bisobank
There are 2 phones connected at same time along with the laptop.
@Bisobank  how strong is the Wi-Fi signal on your phones? Where is the router kept in the property?
This message was authored by: Paul109
I am having the same issue. Just reset my router and same problem that start since last week.
Signal is strong and issue happens when next to router. No Internet.
This message was authored by: RikerPicard
I'm having iPhones (4 of em) that keep dropping the WiFi,, TVs and game consoles seem fine
This message was authored by: Tag64
We have 2 phones that WiFi keeps stopping , this has been happening for the last few weeks ??
This message was authored by: ajmcc40
This did not answer my question
