Discussion topic: Wifi issues
Message posted on 30 Jan 2026 12:41 AM
Wifi issues
WiFi is not working again, 3rd time this month, rubbish broadband, fix this now!
Message posted on 30 Jan 2026 01:56 AM
Re: Wifi issues
I'm having the same issue
Message posted on 30 Jan 2026 02:37 AM
Re: Wifi issues
As am I. WiFi drops every day for me & I even had my router replaced. Rubbish broadband.
Message posted on 30 Jan 2026 03:38 AM
Re: Wifi issues
As you have posted in the early hours of the morning it's worth pointing out that any broadband issues between midnight and 7am could be essential overnight maintenance taking place which is carried out then to minimise disruption. There’s no pre-warning of this. See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
Hopefully it’s back up and running before 7am. If it’s not, try restarting your hub or post back in this thread and we can try to offer additional advice.
Message posted on 30 Jan 2026 08:49 PM
Re: Wifi issues
It still isn't working, please stop making excuses, this is a re-occurring problem, the same I had the other day.
Message posted on 30 Jan 2026 08:51 PM
Re: Wifi issues
It's not an excuse. Overnight maintenance is very much a thing and a common topic on here.
With any broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
