Discussion topic: Wifi issues
This message was authored by: RossUre
Wifi issues
No connection wifi not available
Re: Wifi issues
@RossUre
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back up and running before 7am.
If it's still down after 7am use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
