Discussion topic: Wifi issues
Message posted on 16 Oct 2025 09:05 PM
Wifi issues
Message posted on 17 Oct 2025 07:07 AM
Re: Wifi issues
@ClareCronin most likely cause is poor wifi signal level in the room you are streaming TV which requires a good steady delivery of data.
Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
