Discussion topic: Wifi issues as per usual
This message was authored by: Janip1
My wi fi is keep cutting out , 0% on spin most of the night 31st jan 26 . This wifi is rubbish .
Re: Wifi issues as per usual
@Janip1
Try running this line test to see if it finds any faults:
This message was authored by: Jamie245
Same here. It's went 6 times since 10 PM....
every time I run a check it says I'm back up and running. I am NOT.
@Jamie245 the service checker does not pick up line issues instantly it takes up to an hour. The best way to check is to look st the lights on your hub (see https://www.sky.com/help/articles/hub-lights-explained-start) which show whether the issue is with the line or in your home network. If your line is dropping repeatedly call Sky to get it checked out. If however it is aWiFi issue in your home thst can be down to inteference shere the best solution is normally to improve the WiFi signal by getting an extender or similar.
Avatar for Janip1
Mine is the same every day, when I do the test it says its ok and its not . Its frustrating.
