Discussion topic: Internet not
This message was authored by: LisaKingsbury
Internet not
Our internet is not working and the internet light on the router is not coming on but Sky online is saying there is no issue
Re: Internet not
@LisaKingsbury
With any broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Re: Internet not
@LisaKingsbury Heads up the Light is correct, and the software check is wrong! As to why your light is NOT on then that is the question that needs answered, the difficult one!
This message was authored by: MOH2020
Re: Internet not
Currently having the same issue.. power and WiFi light on but no internet light on
Re: Internet not
@MOH2020 Are you happy with the answer that the Light is the one to trust? If so then a couple hours from now sky May/Or Maynot have the required data to the reason why your Internet connection is down!
