Discussion topic: Wifi issue
Message posted on 08 Apr 2026 04:23 PM
Wifi issue
Message posted on 08 Apr 2026 04:41 PM
Re: Wifi issue
@Toshiro73 what hub and boosters do you have? As you mention lights for each band I assume the boosters are not from Sky. One possibly explanation is if you have thecwhite Sky hub it can use higher channels in the 5GHz band which older boosters don't support and the hub offers no way of controlling the chznnels used.
It is always recommended to use matched boosters to the hub. So either usexan all Sky system or turn off the hub's wifi and usexa third party mesh system linked to the hub by Ethernet.
Message posted on 08 Apr 2026 04:58 PM
Re: Wifi issue
I have the white wifi max hub, I'm using my own extender which is tp-link re550 (ac1200), which as worked fine with it for last 8 months , I've even reset the extender and reset up with wps but still no 5ghz light, I've completely unplugged the extender and just use the router and. Still devices only find the 2.4ghz channel and only getting the lower speeds when running the speed tests I'm assuming the 5ghz channel is not working even though the app and test program saying all working.
