Discussion topic: Wifi issue
This message was authored by: JadeyMarie
Wifi issue
Multiple times a day my wifi stops working. Lights show green orange green orange. Why does this keep happening?
Re: Wifi issue
@JadeyMarie
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
