Discussion topic: No internet again
This message was authored by: christie289
No internet again
As usual after a couple of months the internet has stopped working! Tried the usual reset etc but still not working.
3x green and 1x orange/red light. Can anyone help please?
Re: No internet again
@christie289
This advice was on the last thread you posted on in September …
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
