Discussion topic: Wifi isnt working
Message posted on 12 Feb 2025 06:30 PM
Wifi isnt working
WiFi has been off for 2 hours now, it's been on and off for a month, it needs sorting, we are wasting our money on WiFi that doesn't work
Message posted on 12 Feb 2025 06:34 PM
Re: Wifi isnt working
@Cj76
In addition~
▪️ Any engineer visit that’s required is still likely to be delayed due to the disruption from the recent storms.
▪️ This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
